Hi so lowering my hall ceiling 4m long by 960mm wide. I have framed round the outside with 3x2 cls and also across every 600mm would you say I needed to run studs up the middle ?
Sorry, I should have written maximum 450 cts which is what BG would tell you for 12.5 boards. But you are right.Depends on what size boards you are using, surely. 1800 x 900 then 450 centres, 2400 x 1200 then 400 centres
Thanks but I did 600 centres so I have to move them anyway450 is still OK for 9mm, here you go, knock youself out : https://www.british-gypsum.com/~/media/Files/British-Gypsum/SITE-BOOK/SITE-BOOK-Full-Publication.pdf
Correct but unless I can get a hand I will be cutting the sheets to what I can lift myselfThe critical thing,surely, is to set the joist spacing so that the joints between boards are carried by a joist. 450mm on standard 2400 x 1200mm boards doesn't work, whereas 450mm on 1800 x 900mm boards does (conversely those boards don't work on 400mm centre joists)
