After bleeding all of the radiators in the house, I discovered that the pressure had gone very low on the boiler (Worcester 30si). I knew how to increase the pressure, having found some advice on this site a few months ago. I opened the tap with the plastic key underneath the boiler and turned the square plastic nut until the water pressure began to rise.
Unfortunately, I didn't close the nut in time and the pressure went up to around 3 bars. Now I can't get the pressure to come back down! I've tried bleeding one of the radiators - I must have taken several litres out of it but, if anything, the pressure's increased! There is water trickling out of the overflow outside but it's been hours now and it's obviously not solving the problem.
Is there another way to release some pressure? Is there a particular trick to lowering the pressure by bleeding radiators? Should the heating be on/off? Should the other radiators be open/closed? Should I choose a particular radiator? Please help!
