lpg to natural gas cooker
22 Aug 2009
Belfast
i recently bought a freestanding gas cooker off of gumtree. its set up for lpg gas bottles. Is it much of a job to change it for mains natural gas? will be getting qualified plumber to fit. just curious. many thanks
you'll need the replacement injectors, without them you'll be stuffed.
who ever converts for you will need the jets and the manufacturers intructions.
you'll need to make sure you have them
depends on the make/model some cannot be converted.
you will need a conversion kit consisting of 6 injectors 1 oven thermostat and a oven flame failure unit i know did at least 200 in isle of man six years ago
What's the OvenStat for?
All you have to do is adjust the by-pass rate as per MI ;)
However you WILL require the correct NG injectors for the Burners!!
Or replacement bypass jet for each control.
A lot of cookers are deemed NOT convertable by their respective manufacturers.
