Hi, my son's radiator seems to be only partially full of water and therefore doesn't heat up properly. I have used a radiator key to air the radiator and although some air comes out, the water never comes out when all of the air is released. Also, the radiator makes a lot of clunking noises and sounds like a kettle boiling when the heating is switched on as though it is not full of water and thus, the radiator is only hot at the bottom. How do I fix this and make sure the water is topped up?
Also, my other son's radiator starts making a vibrating noise about an hour after the heating has been turned on and only stops when I move the thermostat on his radiator higher. I usually have it on a No. 3 setting when it vibrates and have to move it to No. 4 or 5 for it to stop which is too hot for his room. How can I fix this so that I can set the thermostat on his radiator at any level without it vibrating?
