I have a Glow worm boiler and hot water tank. When I turn on the Hot water and Heating both Actuators switch to 'B' but the pipes either side of the actuators do not always heat up. I have to switch everything off at the timer and turn the Hot water on first, when the pipe starts to get warm I can then switch on the Heating and it will then work.
Last night I left them both on all night and the radiators were hot and the Thermostat was set at 19c. This morning the radiators were cold and the water only luke warm. The radiators should have been on because the Thermostat clicked at around 15c.
I am relying more and more on my immersion heater because however I set the Heating/Water timer it doesn't always work.
Any ideas ? The Actuators seem to be doing there job and the Boiler is firing up but sometimes the hot water is not feeding through.
