lutron two way wiring help
15 Oct 2006
hi I have a lutron rania single gang switch and a accessory dimmer I have no problem with the main light switch but I don't know how to wire the two ends of the strapper wire running across as I am not sure what connections and at what terminals to connect to could someone please help
thanks col
I can't remember exactly but I installed some around 12 months ago.
All the dimmers come with wiring instructions which detail exactly how they should be connected.
http://www.lutron.com/techInfo/InstallGuides/030890_12.pdf
"Accessory Dimmers cannot be used to control lighting loads directly. They must be used in
conjunction with a Rania Dimmer to provide control at one or more alternative locations."
I'm not sure you can use a switch and an accessory dimmer.
