- Joined
- 15 Jan 2020
- Messages
- 14
- Reaction score
- 0
- Country
So - am I crazy or can I just use LVT (probably SBC) on the walls in a bathroom?
The tiles are fairly waterproof (adding silicone into joints), they're light, can look like stone while being lighter, easy to cut+handle, can be used on the floor too, you can get corner joints or do the traditional clear silicone, cheaper, no need to grout or worry about a levelling system (although you probably want to have them as level as possible which you can do), simple adhesive rather than quickset/thinset mixtures, slightly more flexible/forgiving than ceramic tiles + grout so no cracks, less damage etc.
You could even use screws to secure boards to the walls (or brad nails if you have a stud wall) incase you think the adhesive might fail.
So I guess I am asking: what are the actual pit falls of using LVT on the walls in a bathroom?
Using SBC there shouldn't be much of a need for expansion worries - even if there were some expansion you can have corner channels and silicone giving that.
I didn't see anything in here about using LVT on the walls, and I only see a couple of videos/websites mentioning it, so I thought it was at least asking what is actually wrong with it other than "we don't normally do that" or "get someone in who can tile".
Thanks for any contribution to the discussion..
Old486whizz
Old486whizz
