Hi
I have an outside tap which is fed from a lead pipe. This lead pipe is a mains pipe. It recently started leaking via a tiny hole. After reading some previous threads (which suggested to tap it with a hammer as this would seal a tiny hole) i tried this, and it made the hole worse!
Now I have brought some LX leak repair glue. Will this work on a lead pipe and iff so, whats the best way of applying it? Do i apply it directly, or so i apply it to a bit of rubber and use jubilee clips?
