Lyric T6 Wired Thermostat
12 Oct 2017
Could anyone confirm if the wired version of the Honeywell Lyric T6 actually uses wired communication between the stat and 'relay box', or is it just a power supply to the stat, with wireless communications? Honeywell's literature doesn't make it clear, and the installation guide (https://www.honeywelluk.com/Documents/All/pdf/Lyric_T6_Installation.pdf) mentions binding, unless that's been copied from the wireless version's instructions accidentally.
I'd prefer wired communications, one less thing to go wrong! I realise there is a wi-fi connection from the stat, but as I understand it this isn't critical for operation.
This would be fitted to an Intergas combi boiler using Opentherm.
Thanks in advance.
Wired with live and neutral plus 2 more cables to connect to either OT or normal on/off switches
