I use (Win98se) 'Windows Update', to have a reasonable chance of being up to date etc etc.
Used qfecheck.exe from M$ ... checks if registry entries and actual update files match up .. regards to update version numbers .... result Ok, as expected.
Uninstalled one of the recent update files and deleted it, reinstalled the previous update file having a different version number .... All appears ok. Reboot etc.
Check again, the file / module is there, as expected, and reported in use via my process viewer.
Now run the Web based 'Windows Update' tool .... It has a look ... somewhere, I am guessing the registry ..... Offers me no updates, therefore is happy ... Allows me to peruse my update history ... All fine.
Now .. the question, how to force the update tool to RE-install updates .. I presume the 'audit' of updates applied to my M/C, via the update tool checks only the registry entries ??? and not the 'actual files in the relevant directories' ??
manual drudge then I suppose !!
This is the Catalogue for M$ updates ... enables downloads of any / all releases for the Op System in question.
http://v4.windowsupdate.microsoft.com/catalog/en/default.asp
Yes, have ordered the M$ update cd ... ( only current to Oct 2003, apparently ) No, not holding breath either !!
Should be able to build a full CD of updates from this and the downloads.
Just have a look see .... are the update numbers comsecutive ? are there dates for all ? ...... Just want a chronological list by release date !!!!
Bit of a question, bit of a rant.
P
P
