M08 Replacement glass size
24 Aug 2006
Nottingham
Hello everybody
Need to reglaze a velux as students have damaged the internal pane. Trouble is I dont want to remove the gubbins to measure the glass as I am concerned this may fail whats left of it and I wont get my sealed unit the same day. My glass supplier has a list of some velux panes except m08. Does any of you know the pane size as this would help me out big time. And as for velux sending me a replacement - £100 from TP, I can get a quality unit that size for £30.
Cheers
A tip for you....
On a dg unit from the inside face/edge of the spacer bar to the outside edge of the glass is usually 12mm, so with this in mind flip the velux over and measure the width in between the 3 sided aluminium plate, the one with the cross headed screws in, then add 24mm, do the same for the height from the ali down (or up) to the tin.
I did 4 of these only 2 weeks ago, all fitted fine, infact i could of added another 5mm to both width and height. From memory they were 4/8/4, i took float out but put toughened back in, ideally i would of like to put lam on the inner pane just to catch the toughened if it broke again.
