- Joined
- 15 Mar 2020
- Messages
- 27
- Reaction score
- 1
- Country
Hey Everyone,
So I have been reading these forums for a while as I am renovating a house.
We are putting in an ensuite, and because the waste pipe is at the back of the house and the ensuite is at the front of the house, we have decided to get a macerator.
I've done a bunch of reading but I do have some questions, for people who have them and/or installed them
I have 2 options on how to run the waste pipe:
Run it 1 meter straight, then verticle (straight up) 3 meters and then straight into the large waste pipe in the loft that is used by the bathroom up there. No joists or anything, the actual hot and cold feed is being fed off from the loft as it was the easiest run.
Run it 1 meter straight, drop down, run through joists in the bedroom and through the hallway joists, into the room at the back where the hallway toilet soil stack goes and join in there under the floor?
I mean they say **** doesn't flow uphill, so as much as the first option would be the easiest my concern is blockages as it's going to be pumping straight up, but all the macerators say they can do 5m verticle no problem?
All joints will be 45 degrees as well, to reduce the chance of blockages.
The next question is only the pressurised waste pipe from the macerator needs to be solvent weld, the sink and shower coming into them do not need to be solvent weld as its just normal gravity and no pressure?
Also the connection to the soil stack that can just be a compress boss fitting as that's where the pressure dissipates into the big soil stack?
Cheers!
Cheers!
