- Joined
- 24 Aug 2004
- Messages
- 3
- Reaction score
- 0
- Country
Hello all,
A friend of mine, who I try and always help out...seemed to have trouble with his Magic Chef (top load-belt driven) Washing Machine last week. I looked at it, and when I did...his clothes was in it, with a tub full of water.
He said that is does not want to spin and drain the water.
So I took his clothes out and siphoned out the water, and got the tub to be empty. I then turned on his washer to the SPIN cycle, well, it did not spin, but I heard the mtor running. Then I just moved one of the fins in the tube, and immediately...the tub started to spin it's normal spin.
I then told him what I did...and the machine worked for a week or so...and he just called me up and said it's doing the same thing.
So, I brought my tools with me, and took off the belt...which was still good...and then turned the pulley on the lower end of the pump....where the belt goes. Well, the pulley turned around...but did not turn the tub...then I kept on turning it...back and forth...and finally the tub did start turning.
That is where I am at this point...as I never opened up the insies of the pump stage...I guess this portion is where the transmission may lie...so I did not want to start taking things apart...that I am not sure of.
So...I took the pulley off...which was on a splined shaft coming from the waterpump/transmission...and I manually turned the spline shaft with a pair of vise grips...but the tub NEVER did turn.
Yes, this is where I am.
If anyone does have an idea on what I should do next...I would be great appreciative.
It seems when I turn the shaft...the tub should turn...but I am not sure...as I am getting into the transmission portion of the machine.
Any help to what I am up against...would surely.
I thank each and everyone for reading my post. I want to help my friend tomorrow...but now sure on what the next step should be.
Sincerely,
Patrick Cambre
Sincerely,
Patrick Cambre
