I'm looking for some advice regarding adjustable concealed shelf support systems.
I'm constructing a "pigeon hole" style bookcase using 18mm MDF, each shelf will be 450mm (W) x 325mm (D) and supported on either end. I've worked out that the approximate maximum distributed load for each shelf will be 40kg exc. the weight of the shelf itself.
I was thinking of using either Magic Wires or Bookcase Strip supports but was unsure as to whether they would be up to the job.
I've looked around for both but have found it very difficult to find any manufacturers recommendations with regards to the maximum loads these products can withstand.
If anyone has any advice on the most suitable system, I'd really appreciate it.
Also with regards to the magic wire system - would I simply route a slot out of the mdf self edge to receive the wire? and would 18mm MDF (-3mm for the wire) be enough considering the weight?
Cheers
Cheers
