first post-greetings all
wow, the workshop manual for the magna 1994 3l v6 is unavailable to the public. The haynes manual is riddled with dis-mis info.
Water leak. Engine over heated badly.
Had to change water pump, which, of course, is the least accessible, having to take off drive belts, timing belt (which was so worn it snapped while trying to loosen crankshaft pulley bolt.)
The manual gave vague instructions, leaving out the most important points.
A mechanic told me how to lock the engine from turning by taking off the starter motor and jamming the gear. Great, thank you, it worked.
OK, then the new timing belt, (after finally getting the new water pump fixed in place,) being continuous loop, revealed that the engine mount had to be removed!
Ok, the engine drops!!!
Jammed it up with a shovel to spread load on ground and a flat wide bit of iron to engine. Got the mount off, timing belt on, lots of fiddling and praying that the teeth were right.
A couple of revolutions showed TDC's all ok.
Put the mounts back and lowered the car so the bolts came up and raised the engine the last bit by tightening bolts. Put all else back.
Surprise, by 1 am the car kicked into action. (likely got neighbours riled ) Took it for a drive. Squealing when turning and when air con on. Simple, more tension on drive belts. Done. Happy and relieved, plus prob about a thou or so more in pocket than if a mechanic (who CAN buy the proper workshop manual from Mitzubitsy) had done it.
Q's :
Next, the over heating seems to have damaged something so the low idle fluctuates and engine stops when at lights when engine is hot. Suspect vaccum??? Temporary fix, increased idle speed.
The plastic radiator tank (top) is held on by lugs, prob alu maybe stainless.
Hesitant to remove to rod radiator out. Don't want to risk damaging lugs???
(Don't Mitz want to sell cars? Where to get a proper workshop manual?)
Q's :
