Spotted my magnaclean has been leaking, on closer inspection i reckon it's one of the valves that is poorly made.
if you look at the nut that connects to the magnaclean body side on, it's approx 15mm high on one side, but the other is about 12 mm. I think as a result it's not pressing evenly on the flange and so not sealing the rubber washer to the magnaclean body. It's noticably squint.
It must have been like this for a while as the magnaclean has a tide mark in it where there must have been an air pocket.
The plastic threads appear to be ok and the plastic part has not been crushed/deformed.
Forgot my warrenty card so haven't called up Adey yet, but I diy fitted this and didn't register it, do you think I'll have problem getting anything out of them.
Doing some other work this weekend so am just going to remove it and re pipe that section for now.
