Magnacleanse connection via Fernox TF1
4 Feb 2007
Dorset
Hi
Just managed to get a Magnacleanse complete kit 2nd hand which I collect tomorrow
I have a TF1 22mm installed & want to connect the Magnacleanse via the TF1 isolator valves
Please could you advise how I could connect this up as I’ll need to buy some extra bits to connect is up, I think the connection to the TF1 is 1”?
Need to be able to connect this to ¾“ drain hose to the 1” TF1 connection, is there any push fit that can take this type of hose
Thanks in advance
Dave
A second hand Magnaclean sounds like a disaster waiting to happen
Thanks..... it's a Magnacleanse not a Magnaclean
Thanks Rich, is there another way of connecting it without one of those (i.e. elbows, hoses, reducers) as they are about £65
Adey state they can work alone without a powerflush, simply closing of each rad in turn & using the VibraClean, have watched a few vids doing this without a powerflush
Finally picked up the Magnacleanse, it appears to have 3/4" & 1" BSP fittings
3/4"
1"
The Fernox TF1 uses 1" fitting so I have ordered 2x 1 Inch BSP Brass Male x Female Elbows to connect to the TF1 isolators
Will update the post when I have the Elbows to confirm that it fits
Hi PD,
I new to this stuff, so a bit confused. If you already have a magnetic filter fitted, why do you need the magnecleanse? Does it come with a couple of extra pumps (like a powerflush), or is the magnacleanse just two magnaclean filters in series?
I had the TF1 installed from when the I had the boiler installed 3 years ago but have been having problems with kettling & have had to add 3 different lots of x800 to get the system clean
The system was power flushed including the magnacleanse which the installer used, I'm not convinced that the installer used any chemicals when they flushed the system, as the system is now completely black with sludge
I want to be totally sure that the system is as clean as it can be before I put in a new pump & 3 port valve
Even after 3 lots of x800 & refilling nearly 5 times the water is still black
Dan maybe right the TF1 may not be doing a good job of catching the all sludge, as the magnet isn't in direct contact with the water, I may decide to change it to a magnaclean if I find that it isn't keeping the sludge out of the HE, it may be that it's the amount of sludge that the TF1 cannot cope with
@Samuelle22 -- it doesn't come with a pump it's just another filter with stronger magnets to get the system clean
Someone has put a video on Youtube of it working
https://www.youtube.com/watch?v=lePhWrD8Bgk
I will sell it once I have cleaned the system, only paid £240 so will resell once done so it won't cost me anything
Get a professional in who now's what they are doing. It will be cheaper in the long run than a bodge job flush that may do more harm than good.
Thanks but the installer was supposed to be professional, cannot trust them, shall only use a for Boiler servicing only, that way I know it's been done correctly by myself
Had to purchase the Fernox flushing adapter as the elbows were too big to fit one side by side
Have now cleaned the system & got the water as good as it's going to be
The Vibraclean certainly did the a really good job of getting rid of the loose debris inside the radiators, even after the 3rd go over 3 days there was still pieces coming off
Then connected a garden hose to the flushing adapter & flushed the Hex + each rad in turn which really got rid of all the rest of the crap out of the system
1st time using the vibraclean got this much out
2nd time
3rd time
finally 2 days later
The water is very hard in this area
Tested the mains water with a TDS meter & it's getting 280ppm from the tap
Tested the water in the system & the reading was 310ppm
Is it worth me fitting a aquadial combicare filter to the mains water supply after the kitchen tap as the boiler was kettling which I started this process in the 1st instance would this affect the PH of the water in the CH by fitting one?
