Just moved houses and the central heating (gas, normal (not combi) boiler, microbore pipe work) is making a knocking noise through the radiators. Boiler has been regularly services, paperwork to prove.
I was thinking the cause was maybe sludge and read up that microbore doesn’t like being powerflushed so thought of fitting and using a boilermag filter. Fit filter, dose with flush, etc.
I have three questions if I may.
1. Is the knocking/banging radiator noise likely to be caused by sludge?
2. Will fitting filter and flushing system that way be ok? I was looking at powerflush but there is a lot of info on not doing that with a microbore system.
3. I thought I may as well fit a filter anyway but Boilermag fitting instructions say fit on return after last rad and ‘advise’ against fitting anywhere where it may freeze. My problem is my boiler is in a cold garage which may get down to freezing temperatures. I could fit earlier in the return but that would be before the last rad. Would his be ok or do I fit it just before the boiler and risk it freezing?
