- Joined
- 18 Sep 2019
- Messages
- 3
- Reaction score
- 0
- Country
Hello, I've been reading lots of posts on here and thought I had a solution to my problem but after some investigating I ain't so sure. I'll start with the symptoms:
Main HE 30 Combi.
Differential valve push rod stuck out, so micro-switch was always engaged, so constant hot water demand. Lots of crap around where the push rod comes out too. Hot water works fine - when I need it!!
I removed micro-switch just to test the heating. It came on, but the burn only lasted for maybe 30 seconds, then stopped, then after maybe a minute it would start a burn again, only to repeat.
This made me wonder if the push rod issue wasn't the only problem, but I had a look. I got a diaphragm repair kit, turned the inlet / outlets off and ran a hot tap. Quite a bit of dripping when I removed the front of the differential valve, which scared me a bit so I stopped! The differential mechanism was totally solid, the spring would not move at all.
Does this sound like a differential parts (spring, rod, diaphragm etc) replacement, or a problem further back, into the diverter valve. Baxi suggest it is but I would like a second opinion.
Thanks in advance.
Main HE 30 Combi.
Thanks in advance.
