Hi ya Fellas
Got an Main 30 Eco that has a developed a no hot water fault.
Started noticing water losing its heat when running for a while.
Heating is fine.
Fault developed to no hot water once tap had run for 20 seconds with bolier clicking like mad.
Opened flap and when asking for HW neon indicator flashes from heating to HW with audible clicking. checked fault diagnoses which pointed to hall sensor which was also flashing its red indicator on and off.
powered off and carefully removed sensor then removed the valve which I assume to be some kind of restricter solenoid (instructions stated to clean filter on the bottom). Pretty clean when I did so with no blockage. Reassembled and cleaned cold water feed inlet filter for good measure which was also pretty clean.
Power on reset and now get nothing when asking for HW. Heating still fine.
No neons no flashing no clicking and of course no hot water.
Ive looked in parts diagram and it just gives complete hydraulic inlet assembly and not the solenoid/restricter but I have found someone on ebay flogging what looks like the part.
http://www.ebay.co.uk/itm/MAIN-COMB...arden_Hearing_Cooling_Air&hash=item43c98655f4
Any thoughts or assistance.
Heating is fine.
