Evening!
We had a Main eco elite 25 installed in November 2014. It's always worked well but recently it has developed an annoying whine when the central heating is on. It doesn't whine all the time and takes a few minutes to get going but I used to be able to stop it by a quick run of the hot tap but this is now not doing the job and anyway, presumably there is an underlying problem or it wouldn't be doing this in the first place?
I'd wondered whether the problem could be the fan or the diverter valve. I'm leaning towards diverter valve as if it was the fan I wouldn't expect running the hot tap would make any difference.
I live in a hard water area though not sure if this makes any difference? Having done some research it looks like this boiler has a diverter valve cartridge which sits underneath the valve actuator actually inside the diverter valve 'assembly' (probably not the correct term!!). Would this cartridge be likely to get problems from limescale? Could it be taken out and cleaned up?
Anyway, i'm fairly handy at plumbing and would like to know whether this is a job that can be DIY'd (assuming you guys even think it is the valve) or whether it is likely to be something else/the fan and best left to the professionals.
Just to add: CH/DHW both work fine. It's just this annoying whine which is driving us mad...
TIA
TIA
