My problem is:-
1. My water heater cuts out about 1 minute after I turn off a hot water tap.
2. With the hot water turned off, when I re-ignite the water heater, the main burner goes on rather than just the pilot light
3. After a minute, the water heater cuts out because the water temperature has got too high.
4. If I ignite the water heater whilst the hot water tap is running, it will be fine until I turn off the hot water tap when step 3 above occurs once more.
My suspicions are that it's either the gas valve that's stuck open or the diaphragm, but would like a more expert opinion.
