A good start, but where's it connected in the house?Bit happier now.
Particularly in installations of that vintage, it's not uncommon for the earth bar of the CU to be used as the MET, so there might well not be an 'external' MET to look at. I fear that this issue may have to be resolved by measurement.There should be a Main Earth Terminal (MET) somewhere near you consumer unit (the box of MCBs).
When eric mentioned the 300mA RCD, he did not point out that whether or not that (rather than a 100mA one) would give an adequate degree of protection would depend upon the the 'earth fault loop impedance' provided by your TT electrode (assuming that it is connected). A measurement of that impedance (which you could not do) would therefore be necessary before one could contemplate such a change. I think it's probably fair to say that a good few TT installations are fairly marginal in this respect, which is probably why 100mA RCDs are, I believe, all-but-universally used to protect TT installations. You also would probably not be able to do the RCD change yourself, since it would involve getting your electricity supply temporarily 'switched off' (by getting supplier to remove their fuse).1. Having no real reason to assume the earth pin is not connected to the house system leaves me with the way ahead for my original problem of trip-outs. Perhaps I should go ahead with the fitting of an S type RCD of 300mA instead of the present 100mA unit and see if that helps?
With the aid of a long enough bit of wire, you'd be able to confirm that the earth rod was connected to your installations 'earthing' system, but you would not be able to undertake the measurement referred to above (to assess the adequacy of the earth rod,particularly for a 300mA RCD).2. Is there some way of testing the earth pin connection integrity with my simple multimeter or is something more sophisticated required.
Eh? Just use the ohms range on the multimeter.If I form a circuit with the earth pin and the earth in a house socket with a 12 volt pack and only complete the circuit with my multimeter, that should prove it is connected?
