Hi all, hope someone has a idea! I am planning an extension at the rear of my house and have come across a bit of a problem. There is a manhole cover in the way of the footings and i have to move it, the problem is that this is the manhole over a 6inch communal sewer and the pipe the whole width of the garden is coverd with a foot of concrete.I am planning to build over the 6inch sewer pipe but would like to replace the whole length under the new extension with plastic to eliminate any joins and possible problems.Any ideas on how i can transfer the constant flow of poop whist i work on the pipe and is it possible to connect plastic to 6inch clay without causing and possible snag points inside the pipe?
cheers for any advice
