. Well, yes, I didn't want to 'name names' when I talked of "one of those people who...." However.......Only a problem for you if you were one of those people who believes that to unnecessarily bond something which is not an extraneous-c-p (which is what the pipe entering the flat would then be) is undesirable, since it can theoretically increase hazards.
So are you saying that you would bond the pipe (to the flat's MET) where it entered the flat even if it had a very high (probably not measurable) impedance to earth, because of an insulating section?As has been said that would remove any earth potential but then it may be possible to introduce other potential of which you would be unaware. ... I would, as is illustrated in GN8, separately bond each flat to make each an equipotential zone.
Kind Regards, John
