I AM LOOKING TO FIT A NEW SHOWER USING THE MAINS PRESSURE FOR THE COLD( 15 MM )AS IT IS ALREADY PIPED INTO THE BATHROOM.
THEN USING A SURREY FLANGE FROM THE HOT WATER CYLINDER TO A PUMP
MY QUESTION IS
(1) I WILL USE 22MM FROM THE CYLINDER TO THE PUMP
THEN AS THE PIPE WILL NEED TO GO UNDER THE FLOOR USE 15 MM FROM THE PUMP TO THE SHOWER ( A LENGTH OF ABOUT 8 FEET )
IS THIS OK ?
(2) IS THERE ANY PROBLEM YOU CAN THINK OF USING THE MAINS COLD SUPPLY AS MOST SYSTEMS i've SEEN USE A COLD WATER SUPPLY FROM THE TANK
(3) WHAT BAR PUMP WOULD BE RECOMMENDED FOR THIS SET UP ?
MY QUESTION IS
IS THIS OK ?
