Mains cold water feed to a new electric shower.
11 May 2004
Bath
Hello. Is it alright to tee off from the cold water feed that leads up to the header tank in my loft?
I have a indirect vented system and I have mains fed cold water in the actual bathroom and a cold water feed up to the loft (and the tanks).
I'm guessing that it shouldn't matter, but I have experienced pipe vibration when running the taps in the bathroom.
I removed a non-return valve that I installed just under the shower unit and this seems to have cured the problem.
I haven't quite finished the installation and would be glad of any advice.
p.s. I am getting an electrician in to do the wiring. Thanks Giraffe
:cool:
Should fit isolation valve along the horizontal pipe I have tee'd off from the mains feed in the airing cupboard, rather than on a vertical pipe leading up to the shower?
:confused:
:confused:
Not sure what you mean :LOL:
Tee off the rising main and whatever you feed put an islating valve for future service. ;)
That should have said "should Ifit ..."
That's great though thanks for the help!
I wont bother with the no-return valve as it seemed to be the source of the vibrations in the pipe.
:p
