I've replaced a previous shower because its heater packed in. New shower is a Mira Sprint 8.5. Connection was quite easy because power & mains water already in place. Only differences: a new flow isolator just before the shower, operated by 90 degree turn of a screw and a new 40 amp fuse. The handset is the one supplied (i.e. new) and is not blocked.
The shower unit has a temperature control dial, a flow control dial and a start-stop button. I've tried all positions of both dials, including the commissioning sequence described in the guide. Also tried positioning the mains input tap just on and fully on, flushing the toilet before and at the same time as starting the shower.
Whatever I do the water cuts off just a few seconds after pressing start - always the same few seconds, no matter the flow or temperature. From another post here I suspect the solenoid - but this is a new shower, never been used - so it seems unlikely that solenoid would be faulty?
I don't know what the water pressure is in bar but it seems quite normal.
Baffled. Any suggestions would be very welcome
