mains smoke alarm
20 Aug 2007
Gwent
had a electrition around today to give me a price to fit some mains smoke alarms and a heat sensor in the kitchen , he wanted to wire them from the lights but said that he would now have to run a seperate cable from the fusebox as some of the lights he couldnt find a loop live only a switched live any advise please
Well what he's saying is that they'll only work when the light is switched on. Does that sound acceptable to you?
NO, All just my opinion but I would want my smoke alarms to work at night when I'm in bed, I normally do this with the light switched off.
What he is saying sounds perfectly reasonable.
He needs a permanently "on" Live wire to be able to supply the detectors (as well a N+E).
Coming direct from your consumer unit could be better as also if your lights fuse because a bulb blows, do you really want your detectors to go off too?
sorry breezer what i meant was is he right to say we can you normal cable as i thought it had to be a heat resistant cable so it wouldnt melt as quickly if there was a fire and therefore give a longer alarm and no joe-90 it is not acceptable to me sorry for the confusion
gpg1967, twin and earth or three core and earth is fine for mains smoke detectors.
How ever either is not fine for a fire alarm, but you are not having one, only smoke detectors.
You detectors are to pick up smoke, by the time there is an actual fire near it or its cable, the chances are its too late. It does it's job a lot earlier.
And you can always get the smoke alarms battery backed.
