but I have concerns that at the end of the day its still only a combi, flow rate of 12.5 as against 70 odd for a megaflo if the mains pressure is ok I suppose.
no not at all, you've got it wrong. Its 12.5 l/mins only after you have depleted the store. Thats after you've emptied 170 or 100litres of hot water, and even then its only 10min reheat. It won't actually drop to 12l/min either. Its just the figures they give are, 35c rise(delta T) at 12.5l/min.
It will run happily at anything up to 36l/min if im not mistaken, and I very much doubt you have water flow rate that good to your house.
BTW what good would 70l/min be? you would empty a 200l tank in 3 mins!!
