I live in a new build one bedroom flat, built October 2011, and recently we have started noticing a sequence of banging noises after turning off the taps in our flat.
I called Pimlico Plumbers and whilst the plumber was very helpful, the upshot of an expensive call-out was a new water pressure fitting which has only very slightly helped the water hammer. The advice I have been given - which makes sense based on where the banging noise is emanating from - is that there is a loose pipe clipping behind our bathroom suite and tiles.
Clearly this cannot be fixed until tiling is taken out, replaced and even that will only fix one clipping (of course there could be loose clippings elsewhere that later emerge).If there multiple loose clippings then clearly large parts of our ceiling need taking up.
Similarly to most new builds, our water pipes are plastic
Does anyone have any advice? My worry is that there seems to be a very simple solution, but that this solution could cost multiple thousands of pounds to fix.
All help, suggestions and advice would be greatly appreciated.
