Make bathroom fan switch independent of light switch
19 May 2013
Cornwall
Hi all,
New to the forum (and electrics behind the surface) so please be gentle. Ive just installed a new switch into an outbuilding adjacent to my indoor bathroom and I'm using the feed from the bathroom fan for the socket (fan vents directly into the roof of the outbuilding so was the easiest way of getting a feed in). I wired up the socket to test and all works fine. The obstacle I have now is that as I've fed from the fan the socket only works when the fan isolator AND the bathroom light are on.
Is there any way I can wire the socket up so it only relies on the fan isolator switch I.e. make the fan isolator independent from the light switch? The fan will be permanently disconnected as we hardly use the downstairs bathroom so the light switch only needs to control the light and the fan isolator only needs to control the outbuilding switch.
Feel free to let me know if I've made any mistakes.
A fan venting into any roof space is a no-no.
The fan will probably be fed off a lighting circuit so isn't a good idea to put sockets on it either. You need an eleccy to put a proper supply in for your outbuilding.
You have installed a new light switch of a new socket outlet?
Did you use the permitted safe zones for cables, if buried?
Is the circuit RCD protected?
The fan vents in to the roof of the outbuilding????
Now that could be a can of worms.
*firstly as as I am not sure the method of routing and possible non-conformities that you have introduced, I will have hold back until more info is offered!
*You should have taken live, neutral and earth/CPC from a permanent supply not a switched one.
*You should have done a little research and learned and understood the fundamental principles behind what you were doing.
*Dare I ask if any testing was done?
Other way around (new socket off light switch via fan isolator)
Cable goes through the vent and down through the ceiling of the outbuilding.
The vent to the roof space has always been like that, new build house 2008. The outbuilding is only a little bin shed, roughly 1m square.
