I have this task today, replacing a CCTV camera on the exterior of a house (brick) but need to expand the current 15mm hole to 25mm.
The problem is, the CAT5 cable comes out of this hole and access inside is now not possible (wooden flooring).
Options I’ve thought of:
1. Tape 1mm draw wire to cable, push into cavity leaving the draw wire on my side and carefully drill.
2. Same above but use string and vacuum back through.
Am I missing a more sensible, less risky option?
