I'm making an under-stairs multi cupboard setup and want 3 flush/plain doors that will be painted wall colour so they won't look like doors (maybe!)
The 3 doors will each be 500mm wide, 45' (ish) angle at the top, and one door will be 2.2 max, one 1.6 and one 1.2. Hope you get the idea
From another thread, someone suggested buying a premade door and cutting it down. And I've seen 34mm thick doors which are ply front/back and timber frame. Obviously will need narrowing, and shortening/angling at the top, and then cleaned up and edging reinserted/glued. I'm happy I can do that if needed.
But - how much harder is it to just make your own? 3.6mm ply front (and maybe back ) and a frame made from PSE (25 (depth) x50 pre-planning, so 21 x 44 ish plus 2x 3.6 ply) I'm happy I can make it and join it (M+T +glue). And not significantly more work than modifying a bought door.
My main concern would be it warping either straight away or over time - and this is where my skillset/experience is lacking. Also bought doors have card cores which I guess stops them warping. I was thinking of "cheating" and cutting kingspan insulation and contact adhesive for the same effect. But that is 25mm and I can't source PSE @ 25mm finished - so bit stuffed.
So what are your thoughts?
