In what was external, but now an internal 10" wall, I've removed an old first-floor window and brickwork to floor level, to give access to a storage space. The resulting opening is 179cm high x 108cm wide x 28cm deep ( brick+plaster+render ). I want to construct and fit an oak hardwood frame, then a pair of french doors which will be glazed with bought-in d/g units ( noise ) 20mm thick.
I have been advised to 'haunch', or rebate, the ends of the frame top-piece in way of the uprights/jambs ( ? ) so the architrave pieces hide the join line. Good idea - or not?
I'd like to construct the doors as well as the frame, but am uncertain whether my attempts at M&T joints will be good enough. Could I construct effective glued 'loose tenon' joints, also pegging through using the Millar Mini - or similar - dowelling system?
I have a Kreg pocket hole 'thingy', a sliding mitre saw, routers, simple router table, drills, clamps and various other tools - but not a bench morticer. How best should I proceed and are there any tools/jigs/jointing tools I really ought to buy/use? Should I purchase a bench morticer, or could I manage well enough without?
