Popped down the b&q and bought a 35mm bit that was exactly what I was looking for.
Drilled a 2mm pilot hole in the door and then used the new bit (dunno what its called - forstner?) in a standard drill and 2 minutes later was fitting the recessed hinges and putting up the doors.
