Making Led Flash On Alarm Bell Box
18 May 2010
Belfast
ive got a texecom odessy 5e bell box - any way i can make the internal led's flash using a battery?
The box is real but i havent got an alarm on the house.
just tried a 9v battery on it and it flashes but unsure how long that would last
The Amazon flasher is cheap and easy. I used to make something similar with a LM3909 but I don't think I'd bother now! You can get a 12V 1A psu for a fiver and wire it up but you'll need to drill holes through your wall... Also, when you have a powercut, the bell will go off. :(
If you make your own flashing circuit using a CMOS nand gate (4011) and use a high efficiency Blue LED and make it flash every two seconds for a very brief period, a 9v Alkaline battery should last you a whole year, and if you also add a jewl thief to the output of it it will last much longer.
You could also use a CMOS version of the astable 555 timer.
Bernard, you'll need a big battery for the 10mA current drain - 88Ahr for the year?!! :)
I like BIG batteries.........:mrgreen:
But yes it would require battery changes every few weeks. For the limited effect as a deterant is it worth the effort to have dummy bell boxes. ( or real ones with no alarm )
If you can run a wire inside connect to a 12v power supply (an old phone charger or something of the right voltage/current rating) or a 12v car or motorbike battery, then snip one of the wires to the piezo sounder.
with sparkymarka 12V power supply, if the unit is tampered with or there's a power cut the bell will sound.
if the jumper on the bell is set for the internal battery that is.
