Making Plumbing Maintenance Easier Tips Needed
JP_
17 May 2012
OK, so I plan to buck the trend of concealing pipes and fittings behind walls, and go old school in my new bathroom with a simple toilet and basin with easily accessible inlets so taps, waste, valves and everything else can easily to replaced in the future.
So, any recommendations for brands that are easiest to maintain - I'd consider the concealed look toilet if it came with a simple to remove panel for accessing the tank etc.
e.g. more like this https://victoriaplum.com/product/th...ilet-with-soft-close-wooden-toilet-seat-white and less like this https://victoriaplum.com/product/clarity-btw-toilet-inc-seat-simpbtw01
That Dulwich might be just the thing - but without seeing up close, cannot see how easy to access it behind and under.
Fed up with everything hidden behind walls, blocked in, under tiled floors etc.!
I am sure there must be some products out their that make plumbers weep, and others that bring a little smile to their faces, knowing an easy job and early finish is in front of them!
Sanitaryware and shower trays made me weep last time I fitted them - even England made ones are C- rap, the end user is Quality Control now.
victoria plumbing ware are shyte ;)and guarantee you will be sobbing and being aggressive on the phone , so say you haven't been warned ;).
they cater for the tight misers out there ;):)
that goes for b@thstore as well ;)
