Hi, I am wanting to build some relatively small boxes/containers (45-60cm ish) to fit in some awkward places in a campervan. They will mostly have to have 4 or 5 sides making an irregular shape (for footwells etc).
I think Plywood is the way to go (3 or 4mm?) but is there a product that I can use for 'flexible corners' I was thinking about some sort of strip that would act like a hinge allowing separete pieces to be joined ? The construction could than be made 'solid' by accurately cut end pieces (hope that makes sense).
Failing that what is the best way to make reasonably sturdy joins, I haven't the equipment, time or skills for anything fancy Looking at some boat building sites I guess resin is a possibility? Because the joins wont necessarily be 90 degrees I think it'd be hard for me to cut accurately enough for just gluing and panel pins.
Any help appreciated - as you can tell this is all a bit new to me.
