Hi I am building a big shed and I want to build it with a Gambrel roof
http://en.wikipedia.org/wiki/Gambrel
I am going to make the trusses (I think thats what they are called) myself and I have looked in a few books (some American) that give information on building sheds with this roof shape. On some of them they cut plywood shapes out to fit over the joins of the 2"x4" and others they use metal plates, some which are used with nails and some that have a load of spikes. The plywood idea seems too long winded when you consider how many pieces you will need on each truss especially if you have to make many roof trusses. The favoured method seems to be the plates with spikes.
Firstly do these metal plates give you a strong structure? I have not used them before but it just seems to me joins made this way as opposed for example a join which is screwed and glued would be rickety, am I wrong? Also do you put them on both sides of a join?
Secondly the spiked type, can you get them here or are they only available in America?
Lastly anything else I should consider?
Any help appreciated.
