Making Safe or Taking Over?
16 Feb 2006
Lancashire
Evening folks,
In the middle of doing a few jobs on an older domestic install, I've noticed the shower circuit (which I wasn't originally going to work on) has a separate c.u. which is in an unsafe state and no local isolation (only the c.u. itself which is in the basement). I've told the customer and they've asked me to fit a new c.u. (I'd fit an r.c.d. unit while I was at it) but do not want the decor messing with, so do not want me to fit a local isolator. Can I do this on the basis that at least I'm making it safer and note on the cert that there's no local isolation or can I not do one job without the other, because working on that circuit then makes it entirely my responsibility and any defects my problem?
Also related, I've updated the earthing and bonding and I'd like to update the main earth going to the 4 way Wylex bs3036 board from 6mm to 10mm (I don't think they'll will take 16mm) but does this also mean I'm then responsible for that whole board?
Your thoughts appreciated.
Regards,
Anthony
I wouldn't be prepared to only go part-way in rectifying the shower problems: tell them if they want you to workl on it, you must fit an isolator.
You can fit 16. Just fork the stands and put them into adjacent terminals.
