making window templates
1 Aug 2005
Yorkshire
I want to make a window template for positioning in a wall to later fit a standard 1200mm x 1200mm window. does this mean the outer of the frame should be 1200mm x 1200mm thinking the 5-10mm gap around the window is already accounted for in the actual size of the window or are the windows 1200mm x 1200mm meaning the template needs to be 1210 mm x 1210mm. hopefully that is understandable and any help would be much appriciated.
when they manufacture your window to the size you give ie a 1200 x 1200 window they will allow the tolerance off of this so it will be in the region of 1190 x 1190. therefore build your template to the full size of the opening ie 1200 x 1200 and then you will have some play when it comes to fitting the window. Make sure the template is square and braced as well
