Hi, please can you advise how to wire a typical manrose extractor fan with timer direct to a light switch?
I've tried various combos without success. At the moment I have:
Live from fan to live at switch (with light rose live)
Neutral from fan to L1 at switch (with light rose neutral)
Switch live from fan to L2 at switch
The result: the fan comes on when the light is switched on, and stays on!
I am expecting for the fan to start when the light I switched on, and then cut out as per the timer setting. I would even settle for the fan to switch off when the light is switched off.
Could the timer be faulty? Any advise on the wiring would be appreciate. I'm just hoping that I don't need to run a wire to the light terminal from the fan
Many thanks
Many thanks
