- Joined
- 17 Sep 2004
- Messages
- 465
- Reaction score
- 10
- Country
The set-up is
* conventional oil boiler
* hot tank in airing cupboard
* 3 port diverter & pump in airing cupboard
* heating managed by wireless digistat (receiver in airing cupboard)
The 'problem' (if it IS a problem) is the boiler frequently firing up/switching off. It runs for 3-5 minutes. I've heard this can be an inefficient way to run, as well as wearing out parts. True?
With the weather as it is:
* the digistat is calling for heat pretty well constantly
* so digistat shows 'flame' calling for heat &
* receiver shows green (receiving the heat call) &
* the pump is running (constant)
* but the boiler is still switching on & off.
At present the boiler temp setting is near maximum. (Lower level settings and the rads don't really get hot). My guess is that the water temp is reaching that set on the boiler, so boiler goes off, but as Digistat still calling for heat, the pump keeps going. Am I right so far?
If I turn the boiler down, will it run more efficiently? (though rads will be less hot)?
If I turn it fractionally up (to full), will THAT make it more efficient?
Any comments?
Cheers!
Any comments?
Cheers!
