Hi all, I wonder if you can advise please.
I need to put a new combi boiler in a btl property. In the past I've always had main combi eco, then eco elites, installed. Just returned from local boiler supplier and been advised these have been phased out and now Main are selling the Compact line.
So here's the question - One plumbing shop is saying it will only work with a wireless thermostat, can't even set it up without one. The other is saying that this is not necessary and will be fine with a wired stat. Google searching not 100% clear but I suspect it will probably be fine with wired.
Does anyone have experience with these boilers and can advise, and also whether you would recommend them or not as a boiler?
Thanks in advance
Thanks in advance
