Manhole cover problem
11 Sep 2007
I am having extreme difficulty finding steel manhole covers of the following dimensions:
620 x 620 x 20mm
Single Seal
I've been searching around the 'net for ages to no avail. Note: I only need the covers, not the frames.
As it's in the garden it doesn't need to be super strong, as long as it takes my weight or that of the lawnmower then that's fine.
I need to replace two covers, one over the 'solids' and one over the 'water' sections of my septic tank - the existing ones are rusting away to such an extent that the rust has eaten cracks in the tops, so much so that that they almost certainly wouldn't take a person's weight (thankfully they are in my small garden which is hardly used).
Any ideas please?
The likelyhood is that you will not be able to find any.
You will then have to see if you can fit a larger one with a new frame.
Why is this likely to be a problem?
Tony
