- Joined
- 24 Oct 2013
- Messages
- 15
- Reaction score
- 0
- Country
Hi I'm hoping I can pick a smart persons brain as this is baffling me. I'm sure this thread has been posted many times but I'm using my phone to do this and I'm struggling abit. Ok so basically I wanted 2 x pir security lights outside my unit and thought I'd wire it myself as I feel/felt confident to do it. My father was an electrician and he tried teaching me a few bits now and then.
What I have done is ran a new 6A supply in 1.5mm fp200 to a fuses spur for local isolation. From the fuses spur I ran the load to a 2 way switch.
Connections are: supply L - common
supply N - connector
From here I ran a 3 core and earth to a weatherproof adaptable box which then splits off, 1 cable to each Apollo 400w security pir.
Brown connected with brown, black to black, grey to grey and earth to earths.
3 core connection in 2way switch:
Perm L brown - common - with supply L
Neutral black - in connector with supply N
Switch grey - in L1 of switch
All correctly marked and earths connected.
With these connections I thought that when the spur is on the lights would come on via the pir when light settings permit. And then when switched by the 2 way they would come on permanently?
What is happening is when I turn the spur on the lights come on as stay on all the time and the switch does nothing? Have I connected something up wrong or can you not connect 2 pir lights together like that?
light connections are :
Perm brown to L
Black to neutral
Earth to green and yellow
And grey to a spare connection which has a pink/red cable going to the pir and then a fly lead to the lamp.
I would be wry greatly if someone would be kind enough to she'd some light of this for me. Thanks in advance.
JayJay
Perm brown to L
Black to neutral
JayJay
