Hi, trying to figure out how much keraflex ill be needing.
The floor is currently relatively flat screed
The tiles are ceramic 615x205x8mm
Approx. 70sqm being covered
I have done a fair amount or reading and think I need a 10mm bed and want to use something slow setting as I'm no pro.
I have seen coverage figures for a 20kg bad of the keraflex range from 5sqm to just over 1
One adhesive coverage calculator said I need about 50 bags. A palette of 48 comes in at £766 delivered so I want to get the quantity about right to avoid having loads left over.
Has anyone used this adhesive?
Can you comment on coverage?
Is my 10mm bed correct? or should I go thicker?
Cheers.
Cheers.
