MapGrip D1 on plaster. Primer or not?
4 Oct 2020
Hi All,
I have a small area I would like to tile in my bathroom (~1 square m). I scraped the paint, and it is now only plaster. I bought Mapei MapeGrip D1 for the tile adhesive, and I am wondering whether I should use it directly on the plaster, or first apply a primer (I bought Mapei Plaster Primer) before using the adhesive. Would you have a recommendation? Primer or not with D1 on plaster?
Note I will be fixing small metro tile.
Thanks.
If you've already bought the primer it's very little effort to use it now and a lot of effort to strip it all back later because something's dropped off after you thought it was all done and dusted.
Thanks. There is no indication if I should dilute the primer or not. Any advice on this?
