- Joined
- 27 Oct 2020
- Messages
- 84
- Reaction score
- 7
- Country
I have an electric garage door which uses a Marantec 302 868Mhz remote control, but the remote controls (I have two) have both stopped working, and both have the same problem - when I press either button on the remotes, the LED flashes for a fraction of a second, and goes off. Previously, when the remotes were working, when I held the button down the LED would stay on for as long as the button was held down, and the door opening mechanism would work properly. Now the door doesn't open at all. (I can still open it manually, but it won't shut properly when I do it manually, it seems to need the motor mechanism to push it past the final point so that it's properly shut.)
Has anybody else had this problem? Both of the circuit boards on the remotes are clean and appear to have no cold solder joints (although they are all very tiny components so I can't really tell). They were both working fine six months ago, but I don't normally open the door very often (the garage is only used for storing junk), then a month ago neither remote would work properly.
